FMLIST server partially back ...
Aloittaja JJJ, 16.05.2016 - 18:14
It was a quick decision to take the opportunity and move the FMLIST server
to the new environment.
All data entered / updates between May 15,22:30 UTC, and May 16, 12:45 UTC,
is currently lost. We will recover it in the next days if possible.
The database thus is as up-to-date as possible, and YES, you can now fully
use it for logging and editing.
Here are the temporary URLs:
FMSCAN: http://ng.fmscan.org
FMLIST: http://ng.fmlist.org
All other URLs (those starting with www) are not yet working but will be
established as soon as possible.
You are also welcome to report any bugs, errors, strange behaviours, or just
your excitement about the improvement in speed ;-)
73,
Günter
Günter Lorenz (FMLIST)
http://www.fmlist.org/
http://www.fmscan.org/
